Modbus conversion for Baseline-MOCON
Scadaman
Apr 2007
Texas
22
I am working on a Scada project where the device (a Hydrocarbon Detecting equipment) have a RS-232 port for serial interface. But you can only connect to it via Hyperterminal. It only send a one ASCII stream everytime you type "A" in the terminal. This stream send all the data in one shot, space delimited.
Is there any device out there that convert this stream of analog data and repack it into Modbus tables ?
If this is the only communication option on the device is think you need to make a translater yourself. It seems the protocol is quit simple. If the scada package is capable to use simple ascii comms.
Or maybe there is already a dedicated protocol converter on the market. Try the local dealer of the equipment if possible or google.
Hi, Im doing a project with a Power meter that offers Modbus TCP and each signal is a 32bit Float.¨ I tested the float in Modbus Poll and...
22
3,088
Hi Guys, Maybe you have some experience with this set-up and can give me some pointers. Project is to use an Emerson DCS to communicate (via...
2,040
I have an existing Micrologix 1400(B) which is being addressed from an HMI via a PCCC/DF1 driver. However in moving to a new HMI I want to use a...
2,073
Hi gents, i'd like to know what are the guidelines for converting a Micrologix 1100 program to a Contrologix in term of modbus communication...
10,748
I need to replace legacy RTU's with PLC's or other devices that will act as a slave in communicating DNP3 with a master. We must communicate DNP3...
4,528
