ModBus RTU communication Problem
adnan_hayat88
Apr 2013
Karachi
46
I am trying to communicate a ModBus RTU device with Cimplicity. The problem is that the device is giving response on Dos prompt MB Test command but when I configure it in Cimplcity it does not communicate at all. Any ideas? Real stuck here :(
I'm not familiar with your programs but whenever I try to do anything Modbus I try to find one register (date or internal temp or something you can recognize) and work with just that one value until you can read or write to it. Often there is an offset and it's easier to deal with just one point. Also if you are asking for a range and the offset takes you outside of a valid range you can get nothing back. Get that one point reading then expand from there.
Good luck,
Kraken Fan #69
AFAIK all Cimplicity HMI/SCADA versions can talk Modbus RTU, but for someone to help you, they will need to know what driver you are using and maybe it's version number.
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
910
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,521
Hi everyone, I would like to use Micro 850 to control DF FC 102. I adready connect Danfoss fc 102 VFD ( it can run the motor) to Micro 850 by...
1,932
Hi all, Has anyone dealt with Modbus RTU communication using SE`s Machine Expert? I have got the modbus tcp working, but not used the serial...
1,213
we use M580 which have an Modbus RTU port correct if iam wrong now should i have to read input data from ab micrologix through read var block and...
1,865
