Modbus Simulator
edward.ortiz
Jun 2015
Houston
28
Hello, I am working with a Direct Logic PLC. I have created logic that will set the PLC as a master and is reading information from a slave unit. I have an old modbus simulator that i tried using to simulate reading from a slave. Is there any good modbus simulators that anyone recommends?
I downloaded Modbus Poll from Modbustools.com and really like it. It is free for awhile but after I used it a few times I went ahead and purchased the licenses.
CAS Modbus Scanner is completely free and works well enough as a slave simulator:
http://www.chipkin.com/products/software/modbus-software/cas-modbus-scanner/
I do find modscan32 by WinTECH more reliable, but it requires purchasing. You can use it free for the first 30 days as a trial, but for trial versions it stops showing data after 3 minutes have passed.
Funnily enough, you can actually get around that limitation by using Wireshark to monitor your Modbus packets, since the trial version doesn't actually kill the Modbus connection, it just stops updating the data display.
http://www.win-tech.com/html/modsim32.htm
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,929
Installed Peak V3.0 Modbus/TCP slave/server simulator on Windows 10 box. Configured a couple registers and attempted to read from it with a box...
2,380
Gentlemen, I have a customer (he tried to register but wasn't successful so I am posting this question for him) that is benching radios and has...
5,374
Hi All Does anyone know where to download a completely Free Modbus RTU Slave Simulator , continuous session running. Not that kind of free...
15,099
Hi All, First time poster and not familiar with modbus or red lion HMI but I was wondering if anyone can suggest a modbus simulator that will...
7,124
