Modbus Slave on Schneider Quantum 140 CPU3110 10 Unity Controller
Erik vdH
Sep 2006
NZ
42
Hi - I am not familiar with Schneider PLCs at all, but have a question about a a Quantum 140 CPU3110 10 Unity Controller.
It has "modbus" and "modbus plus" DB9 connectors on the front.
I would like to know whether you can configure either of these ports to be a Modbus RTU Slave, so that I can poll it to grab various integer data values from a Modbus Master.
If it can be done, is that much effort to do on the programming side?
sorry, correction, there seem to be three DB9s the top two being "Modbus Comm 1" and "Modbus Comm 2". Can't see the other - I have only a bad photo to go off...
I have never used the modbus ports on a quantum. But attached is the settings for those ports. Cant specify if its a slave or master. Maybe someone else can specify which it is.
Looking for some advice on a project. The controller is a BMEP584040. There is a RIO ring with several drops with Quantum I/O. On this ring...
1,121
Hi all, Sorry to seek help here as I am run out of idea. recently i need to use my PLC(Schneider M580-Unitypro) as Modbus TCP Master to read...
4,466
Hello new user here seeking some guidance. I have been given the task of polling data from a modbus slave (Thermo 43i Analyzer) using RS-232...
1,731
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
155
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
201
