Schneider Electric M221 + Remote Modbus Slave (Serial)
landon1010
Oct 2020
Calgary
Hello new user here seeking some guidance. I have been given the task of polling data from a modbus slave (Thermo 43i Analyzer) using RS-232. Unfortunately I can not get the Read_Var function to work or the Modbus Serial IOScanner to work.... I am trying to read holding registers using modbus command 0x03. Any help would be much appreciated as the program (Ecostruxure Expert - Basic) does not have much for tutorials when it comes to establishing this communication.
Here is some information that helped me.
All you need to know about Modbus RTU.
https://www.youtube.com/watch?v=OvRD2UvrHjE
About Modbus
https://www.simplymodbus.ca/FAQ.htm
Once you know the basics then you can look at setting up the M221 as the master (client)
https://damrexelprod.blob.core.windows.net/medias/241f740c-630a-42ce-8195-4ba057a1871e
Set up your slave (server) on the Thermo 43i Analyzer. Ensure that the serial communication matches and the unit number has been set.
I hope this helps you out.
Regards,
-> Check serial config: baudrates/parity/data bits/...
-> Check CommError and OperError which READ_VAR provides
-> Check device id (modbus address) if it matches with the device
-> Check the block size limitation, some devices does not allow you to read an entire block in a single request, for example reading the following block might not be possible, some also does not allow reading only 40001 since it is a Float32 or a Dword it forces reading the entire datatype.
40001&40002 SO2 CONC
40003&40004 NOT USED
40005&40006 NOT USED
40007&40008 LO SO2 CONC (Dual/Auto Range mode)
(This section is taken from Thermo 43i Analyzer specs)
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
121
I am using a M221 PLC (TM221CE24R) which provides me 1 Rs485 port, which I am already using to communicate with a sensor (Rs485/Modbus). My...
750
Hello, I am trying to detect when the PLC changes from STOP to START mode. This can be considered an edge case scenario, but I would to analyze...
1,570
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
241
Hello, Does anyone know why this AMO 0410 or AMO0410 module flashing all 4 channels with green LED and the IO LED on the display is solid red ...
490
