Modbus TCP Using 1756-L61 and 1756-EN2T
I have both. 2 gateways and 3 in chassis modules from Prosoft. The gateways are just that, providing network isolated data to a third party on a different subnet. Pure awesomeness!
The in-Chassis modules use the same configuration software, which is just OK. Could be greatly improved but as often as you need it I guess its fine.
The one from spectrum looks like a great improvement in configuration - but can't imagine how it would function any better. I still will try one someday.
I need one that can poll an RS485 loop using ascii commands and responses. Hope these show up on my radar someday.
check out the red lion datastation. Thats usually what I use to make AB and Modbus play nicely together. I am sure that they have a raw serial port driver that would work with the on board 485 port.
I believe prosoft do a 1756 in chassis module as well as a standalone unit
Recently did a project and found the in-rack card at around $2000 USD, where the gateway Din rail was around $500.
Used Red Lion Products which are also around $500.
what is model of the RTA gateway for Modbus TCP on one side and Rockwells Ethernet IP on the other ?
are they simple to use?
Yes they are simple to use it Ethernet ip on one side, the other side it serial, also there is a model it one Ethernet port from modbus tcp to Ethernet ip
The best thing they have good customer service
I am working on a project, inside an AB CLX, I implemented the Modbus TCP Client AOI published on AB website, to interreact with a Modbus ASCII...
3,576
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,879
Hi all, Has any of you got any example of reading data from modbus tcp, using FBD? I am just trying to get my head around, doesnt look like a...
2,544
Goal: Panelview+ application reads/writes tags via Modbus TCP. Software: FTV Studio ME 6.10.00 KEPServerEnterprise 5.13.213.0 PVP with 5.10.16...
3,967
I need some help transferring some data from an Anybus Module to a SQL database. Here's what I have so far: I created a Modbus TCP/IP Master...
2,479
