Modicon PLC
Mpoon
Sep 2004
Toronto.ont,canada
41
Modicon PLC Post #1
Testing, I am new here.
My first question.
Are there any people have Modicon PLC programming experence?
I need some help to understand the I/O structure of the Modicons.
I have good experence on AB product, not Modicons. software is(ProWorxNxT)
Are there any simple book/manual or online material that I can read.
Thank you for your kindly response
Modicon
Hi and welcome,
There are fewer of us Modicon users all the time it seems but we are still here.
If you ask a specific question it will be answered. Probably by someone more knowledgable than me but I'll give you what I can.
I have 10 years experience using Modsoft programming software on 984, Quantum etc.
My workplace has not yet switched to Proworx.
Brian
specific question
My specific question are.....
1: Is the Modicon Processor also have simular data file setup?
2:How is the Rack and slot I/O addres. such as how many slot in a rack. how many I/O in a slot?
I just want to undeerstand the I/O and all internal word/bits
arrangements. In AB products it has data table, I is input file, O is output, then B3 for internal bit,T4 is Timer,C5 is Counter,R6 is Control file,N7 is interger file,
Q3 : Is the Modicon Processor also have simular data file setup?
and how is the Rack and slot I/O address
Thanks again
I'm sorry that I saw the PM before I saw your reply here.
I hope I answered some basics. to recap.
1 ?
2. Depends on the product line, typically 5, 7, or 9 slots/rack
Depends on the I/O card, 4, 8, 16, 32 inputs/outputs
3. Addressing is established in the I/O mapping or Traffic Cop
0xxxx discrete outputs and internal coils
1xxxx discrete inputs
3xxxx analog inputs
4xxxx analog registers
More detailed questions equal more detailed answers.
check out the www.shneider-electric.com
Brian.
You have to be a little more specific. Each Modicon model (such as Quantum or Momentum) has different I/O addressing schemes, and for some of the models you have to do bit stripping to access the discrete I/O. In some cases you can assign I/O address ranges, and in others the ranges are fixed. For some analog modules the I/O has to be configured and initialized, and for some not.
There is no separate file structure for bits, integers, floating point, etc. You have to pick the right group from the list Brian provided, and the PLC takes care of the rest.
I'm not familiar with ProWorx, which I believe only does 984 compatible ladder logic.
The Modicon is a little harder to get used to than Allen Bradley, but essentially you can do anything with it you can with RSLogix.
When you come back with more specific questions, you'll want to include the model number of the items in question. Modicaon is actually a conglomeration of old Modicon stuff, new Modicon stuff, and Telemechanique stuff.
All of the Modicon processors have the same addressing scheme, especially when using 984LL software such as ProWORX NxT. Momentum I/O numbers do not line up with the terminal strip numbers because Momentum can be used in the "old" Modicon format, new IEC systems with integrated processor, and as block I/O over many different communication/network protocols. Bit stripping is usually only required when using comination (analog and discrete) modules but the format is still the same.
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
271
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
341
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
We've got this old Modicon PLC on a Mobile Skid that has developed "Comm" errors that cannot be cleared (tried moving cables, connectors etc.)...
1,093
I am looking at a bakery oven that has been dismantled and in storage for unknown time, it was manufactured in 2012 so not that old. my gig is to...
3,620
