Modicon Quantum PLC - BUSY CONTROLLER
Syrist
Jun 2006
Kitchener
17
Hello, I'm trying to access a quantum PLC using ProWorx. Network explorer can find it on modbus plus node 12 but it's status reads "BUSY CONTROLLER". It only started to do this after I tried to reset the PLC by turning off the rack and unplugging the battery.
It seems that no matter what I do the PLC always indicates "BUSY CONTROLLER" and I can't download, get online, etc.
Before I unplugged the PLC the status always showed the correct information.
Any ideas or suggestions would be appreciated... thanks.
-Pete
I fixed it by physically removing the PLC and power supply from the rack and leaving it off (with battery unplugged) for a few minutes. Weird.
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
273
I have a backup Processor which is identical to the processor running my plant (140 CPU 652 60). If I load the same project into this backup...
1,512
Hi, Any one know how I can check the status of the Ethernet card NOE77111 status or if there is any communication fault? Thank you!
2,341
Hi, I have new Moodicon PLC CPU 140 652 60 and I want to change the IP address, Subnet mask, and the gateway for this plc using the key pad. The...
4,546
hello, we are using modicon quantum plc and its progrraming software concepr2.2, we have one repeated problem from last many days that our...
2,219
