Modicon TSX Micro
Ah thanks Jim.
Any idea where I can get the Uni-Telway Driver from? I have done a search on the Schneider site but still cannot find it.
Thanks,
Dave.
No. But, the drivers Schneider uses with their programming software packages are often called XWAY, that might help. Have you tried products from KEP software?
Why do you want to use Uni-Telway and not Modbus? Are you using an optional comm card or just the TERM port of the processor?
Wonderware Ships with an IO Server CD. I have used the Modbus driver before to communicate to with a Quantum and a Momentum. Not sure about the Micro.. Try the IO Server CD first
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
158
Pure mind boggled at this one, can’t seem to figure it out. NO contact with - %M130(%MW11) How is this possible? Is the %MW11 0 it’s logic 0, 1...
1,553
Hi All, i have PLC Modicon TSX 3722 Micro i need to know where should i put the socket of programming cable on Ter or Aux port. and i see the file...
1,645
Is it possible to send and receive data with a custom protocol communication for reading inputs and setting outputs? for example via TER...
1,368
Dears, I am trying to communicate with modicon TSX3721001 using TSXcUSB485 cable i purchased the cable from a local Schneider distributor and...
6,939
