Modicon TSX P57203 - error code FD?
pacak
Sep 2006
Arad
65
Hi there
There is a machine equipped with:
P57203
CTX2AY
AEY420 x 2
ASY800
DEY64D2K
DEY32D2K
DSY64T2K
DSY32T2K
The ERR leds are blinking on the CPU and all modules except the CTX2AY which has the RUN led lit.
My problem is that I do not have the sowftware and cable to check the PLC.
The only information is the message on the HMI:
"Negative response code: FD (TSX57)"
What could be the problem?
What is the Run led doing? If its blinking then either the program is gone or it is not in run mode
Thanks chud for the answer!
The Err leds are blinking.
In the meantime I've found out that there is a memory card in the CPU and it has a battery, so today I will try to replace it.
If the battery is empty, did we loose the program ? :confused:
I'm 99% sure that you have lost the program. There is normally 2 batteries in those memory cards.
Hi!
Battery (the bigger one) was replaced. The program was gone.
Fortunately a backup copy has emerged from nowhere so we're lucky.
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
139
Hello I was needing help with the proper scaling on a Modicon TSX Quantum- AVI030-00 8 Channel Analog Input PLC card. What would be the proper...
1,482
Pure mind boggled at this one, can’t seem to figure it out. NO contact with - %M130(%MW11) How is this possible? Is the %MW11 0 it’s logic 0, 1...
1,538
Hi All, i have PLC Modicon TSX 3722 Micro i need to know where should i put the socket of programming cable on Ter or Aux port. and i see the file...
1,638
