Hi all,
I've been tasked with a project in the factory where I work, quite a simple project.
It involves a water discharge tank with a pump inside and agitator jets.
I'll require the pump to start when the tank has reached an upper set limit and stop when the tank reaches an lower set limit then start the agitator jets for 5 seconds.
I'm wondering what kind of sensor you would recommend using for this project. I'm thinking of a ultrasonic sensor. Would the Pepperl-Fuchs UB4000-F42-E5-V15 be compatible with the Easy500.
Also I will require the agitator jets to run for 5seconds every 2hours, is this possible with the Easy500 series (EASY512-DC-RC).
Any help will be greatly appreciated.
