Moisture in wood
JeffKiper
Jun 2006
Indiana
2,460
Hello Guys and Gals
I am trying to quote a small job checking the moisture in lumber before it is cut. My problem is I can't find any other than hand held or weight scale type systems. I was thinking of a inline with the conveyor that would make contact with the board. If the moisture content was to high it would reject the lumber. They would dry the lumber in a hotbox then run it again.
Has anybody seen or done this that would like to share?
You may want to send a PM to Peter and ask him to respond http://www.plctalk.net/qanda/member.php?u=71
His motion equipment is used a lot in the lumber industry and he may know of something or someone that may be able to point you in the right direction... or point you to some reading material .... like 'trees are us' or 'lumber today' :)
I actually worked on a moisture detector for Weyerhaueser back in 81 or 82
We used capacitance then. Now there are moisture detectors you can buy off the shelf. I would search for dryers
I did and I got this
http://www.westmillindustries.com/lightsort.php
I haven't paid too much attention to dryers and moisture detection since when I worked that project.
You should go to the lumber shows every few years.
I came from the metal stamping world so wood is way out there for me. I did find a few inline moisture systems online but not as many as I had hoped. Thanks for the pointers I will do some more research and post my findings.
hello all, we have little side project cooperating with local University. They are reading resistence between two screws screwed into wood (cca...
2,418
Good Evening , I'm looking for a moisture sensor to read muffin dough going across a conveyor . We have recipes , that should add the correct...
2,998
Hello PLC experts, I have a question for those of you familiar with studio 5k. A moisture analyzer was added to the PLC as a REAL data type tag...
5,239
Happy New Year All! Does anybody know of a decent sensor for monitoring humidity or water in compressed air lines? I'm sort of looking at the...
1,911
Hi All, I have an application where I need to constantly measure the moisture level of abrasive material in a pan mixer. The sensor needs to be...
1,502
