Momentary pushbutton in M8 form factor
LadderLogic
Jun 2003
Chicagolandia
1,486
I am wondering if anyone makes a miniature snap-action pushbutton which looks like a typical 8 mm prox, with a 3-pin M8 connector on one end.
Has anybody seen anything like that? TIA.
Ah, yes. I didn't think of that. Yesterday during my free time I tried to find a pushbutton with an M8 connector, without any luck.
But Kolyur's right. You could put a M8 proximity switch into an adapter, I think they are called Banking Screws by a lot of manufacturers. They have a spring loaded metal actuator, usually used for protecting switches from physical damage but could be adapted for use as a makeshift pushbutton.
Edit:
I don't think they come in Snap-Action though...
I've used the Softnoze devices (they call them "cushioned sensor mounts") in the past to protect prox sensors, with decent results. The sliding component is steel against steel, so they will wear out in high cycle applications. I've had to replace a few but they aren't too expensive.
The "ShortStop" is actually designed to be used as a pushbutton (not snap-action I assume). I haven't tried it but it looks interesting.
We have a compact logix L32E running RsLogix 5000 v.20, connected to two panelview plus 6 1000 over ethernet. 1) One, possibly both panelviews...
2,904
I have created a Vijeo Citect 2015 project with code to mimic a momentary pushbutton. The code sets a Start bit with the mouse button is clicked...
3,156
Sorry if this has been beat to death. I have an old Samsung SPC-10 that I want to use for a gate control. When a momentary push-button contact...
20
4,994
What is a "clean" way to program a momentary pushbutton so that when pushed the first time it will turn on and hold an output and when pushed...
5,037
See atcched pic. Help me to get it working. Normally the green light will be blinking with one sec delay. When you press a Pushbutton (X2) it...
4,261
