Most ridiculously overly-complicated panel you've ever designed
I did a job several years ago where the consulting engineer for the town required us to install a SLC 5/04 at a water tank to read one 4-20mA signal (tank level) and one digital input (valve opened) and provide one digital output (close valve.) I argued for weeks to get them to let us quote and supply a MicroLogix at the site, but he insisted on the 5/04. :confused: More money for us on the project, but much higher replacement costs for the town in the event of a failure.
Yeah, we initially suggested something like that. They turned it down because it "needs to be industrial."
Interesting. I thought that
- DIN rail mounting
- removeable phoenix contact screw terminals (not a friction fit coaxial power plug)
- 24Vdc power (could be redundant if needed)
- a -20° to 70°C temp spec
all qualified that little box as "industrial".
Just goes to show, one can rationalize any thing.
- DIN rail mounting
To some people, if it's not ANSI Gray, it's not industrial I guess.
We had a customer pay someone else about 6 grand for a remote monitoring installation. I went to check it out after it was installed, to put up antennas and make copies of the graphics and PLC program.
It was one RSView screen with 3 valve positions on it. When I checked the PLC source, it was tied to the IO of the PLC - pretty sure it was a micrologix, can't remember the model. I went to the remote location, and there it was, a PLC with no program. I don't even think it had to be in "RUN".
Earlier in the year, I received a series of 4 emails from a salesperson from an industrial camera company. These went to my work email. I don't...
35
18,180
Good Day, I have a simple I% add on project to VersaMax Micro 28 (IC200UDR010) connected QuickPanel View (IC754VSB06MTD)PORT 1 and also Mits VFD...
1,546
hey all, I have been trying to understand the starter software by siemens and I really couldnt understand . Are there any good advanced manuals...
30
7,769
Hey all, I'm working on a project where there are some existing remote sites that are using Automation Direct DL05 PLCs. They're very simple...
3,280
Using CLX I'm building reusable alarm logic with global Acknowledge, well... Trying to. I would imaging that this is a common issue to handle...
7,234
