Now for some marketing info from Rod.
Rod said:
Keith and Peter,
We started out with Delta Tau. But there was too much work on our end to accomplish our needs back then (13 years ago). Boards were good, speed was okay. Now we have to have an order of magnitude increase.
DO NOT get me wrong! They had - and probably now have a seriously good machine! What we needed then and what they had then....
We were forced to move to Acro-loop and at this point we can't back up to DT.
Yes, 10 years ago I would have loved to have their DSP. I envied their processing power. Now processing power is not a problem. I am pretty sure DT wrote most of their code in assembly like I would have done and did. However, it is difficult to change processors when writing in CPU specific assembly language. I know because we are in the last phases of converting our code to C and we are re-writting our setup tool. We have decided to break with the past with our 3rd generation products and use DSPs or PowerPCs so now I think I have them out gunned finally. BTW, I have met the owner of Dimitri Dimitri, the owner of DT. I know he takes motion seriously. DT has been good competition. They have most got the high volume accounts where some engineering time can be devoted to getting the PMACs to run. There is a local integrator here in Vancouver, WA that uses DT in some pretty sophisticated applicatons. Most are in bottling.
Rod said:
Motion control math speeds and internal communication speeds are paramount!!!
Yes, the TMS320C33 we use runs at 60 MHZ and can do 60,000,000 floating point mulitply and adds a second. In reality this is not possible but we can still execute about 50 million instructions a second. We can still increase the speed to 75 MHZ. Compare these speed with PLC speeds. The PowerPC we use has a built in Ethernet interface so we can keep up with the 1756-ENBT cards and whatever else Rockwell designs. Ethernet/IP rocks. Our second generation product was designed to be twice as fast as the PLC5's Ethernet. This is not good enough.
Rod said:
Now were are fighting the ISA EIA ETC comms. Dang .DLLs! XP SUXS!
I wish you would say more about this. I would like you to describe in greater detail what you don't like about the .dlls.
I know XP suxs. It is a poor excuse for a operating system.
Still I would like to know about the troubles you had so I can avoid them.
Rod said:
The ETC comms are the pits!
Again, I would like to have more details. Tell me what your needs were and how the ETC comms failed to meet your needs. I don't want to make the same mistake. This is your chance to affect a future product. I listen. There were some threads about this. Our current product saves the whole project as a zipped .xml file. That includes symbols, comments and labels.
Please reply and expand your comments.
