Motor Brake Issue
zai_jnr
May 2008
MALAYSIA
169
Hello buddy,
Just wondering regarding motor hoist function. In this system I have motor using for hoisting process.
Got trouble with hoisting equipment at project site. The motor brake disc damage and broken. That time, hoist motor at up end position. So, the hoist moving down until the floor..I wonder if there have any mechanical lock for safety in motor construction in case there have brake damage?:confused:
Hello buddy,
Saw this in a shipyard. shaft downstream of brake and motor broke drum kept running in down when block hit drydock floor drum kept running - 1" steel cable all over in crane house.
The only thing I can think of is
1. repair what you have then frequent inspections and keep a set of spares.
2. Put on an additional brake
3 does the drum have a manual brake on it
Dan Bentler
Dan Bentler
Thanx Dan for your reply..
May I know in market there have any spec motor that have safety construction in case motor brake problem ?...I'm not familiar in motor spec ordering...
Hello, I have a MPL-B420P-SJ74AA that went out, but we did not have in stock, so we are replacing with MPL-B420P-MJ74AA. After hooking it up, I...
1,788
hi i try to wire the motor same as the manual, the brake is wiring to pin 43 for + and 44 for common with the diode (page 123). but the drive is...
1,224
I have a number of AB MPL servo motors driving material rolls through our machines. As of late, I am seeing a number of the brakes on these...
3,161
hi i try to connect mpl-a320p-h (motor with brake control) to the ultraware3000. i have problem when i turn on enable in indexing mode, the...
1,056
Hi, We have a EOT crane which has 3 hoists (30T/60T/30T). The issue is when we give command for Hoist Up or Down the the motor runs for few...
1,865
