Motor control in HMI
smichalo
Mar 2007
Mississauga
Hello all
I"ve got a question here that might make sense or not. I'm installing an HMI on a packing machine that we built and we currently drive the conveyor with a DC motor. What I would like to know is if the motor speed can be adjusted through a command in the HMI. I'm using an AB micrologix 1500? I've never done this before and I'm just wondering if it can be done?
And if anybody has done this in the past would you share you idea with me.
The HMI I'm using is an eztouch EZC-S6M-E 6"
Steve
By the way this is a great sight. I found a lot of answers here
Usually you can drive a DC drive card with a variable voltage input, and all you'd need is an analog output card on the ML1500 & a scaled block on your HMI.
Typically a very easy installation.
If you post the DC drive card # or a manual, I'm sure we here on the forum can help.
Thanks CroCop
I don't have that information right now as I am at home. I could get that Information when I get into work tommorrow and post it when I get home. Is that O.K.?
Steve
I spent quite a bit of time researching LinMot Linear Motors, after it was suggested, on this forum, that they would be the best actuator for my...
3,011
I´m working with a Delta HMI (model: DOP-B07E515) and Moog Animatics Smart Motor series 5. I need to communicate both devices and send & get...
3,703
Hello everybody... I am very new to logical controllers but I was given a task to replace our broken t-21 data entry terminal, which is very old...
2,368
Hello all I"ve got a question here that might make sense or not. I'm installing an HMI on a packaging machine that we built and we currently...
2,478
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
242
