Motor control program(RSlogix 5000)
Feb 2006
casablanca
39
Hello,
i need to build a generic structure for any motor control application.
I need to know which are the most common and important elements to be considered or just some program examples.
the aim of this structure is to be suitable for any kind of motor configuration.
Any suggestion is welcome
thanks in advance
Have you tried doing a search of this forum? This is a very basic thing, you might get more help if you show that you have exerted a little effort on your part.
Here is a UDT structure for a powerflex drive. Because of the various ways that a motor may be controlled (contactor, soft start, drive, etc) a truly generic UDT may be difficult to come by.
Data type Name: PFlex_VFD
Description: Full data structure for A-B PowerFlex Drive on RIO
Name Data Type Style Description
ManFwd BOOL Decimal Manually Turn Drive On Forward
ManOff BOOL Decimal Manually Turn Drive Off
ManRev BOOL Decimal Manually Turn Drive On Reverse
InMan BOOL Decimal In Manual
Isolator BOOL Decimal Isolator Status
Interlocked BOOL Decimal Interlock is active when true
Fault BOOL Decimal Device Faulted
LogicFault BOOL Decimal Logically Faulted
Reset BOOL Decimal Reset Fault
AutoFwd BOOL Decimal Run Motor Forward
AutoRev BOOL Decimal Run Motor Reverse
StartTimeDN BOOL Decimal Start Time is Done
Stop BOOL Decimal Output to Stop Drive
Start BOOL Decimal Output to Start Drive
Jog BOOL Decimal Output to Jog Drive
Clear BOOL Decimal Output to Clear Faults
AtSpd BOOL Decimal Drive at Speed
Mux BOOL Decimal C1 DataLink Mux
RIOStatus SINT Decimal RIO Scanner Status
Alarm INT Decimal Drive Alarm Flags
MotorRPM INT Decimal Drive Rated RPM
DriveFault INT Decimal Drive Fault Code
StatusMsg INT Decimal Drive Status (HMI)
FaultMsg INT Decimal Faulted Message
FaultMsgLast INT Decimal Fault Message Last Scan
MessageNo INT Decimal Message Number
MaxStartTime DINT Decimal Maximum Start Time
ParaCountRD DINT Decimal Parameter Read Counter
ParaCountWT DINT Decimal Parameter Write Counter
Load REAL Float Motor Load 0-150% (HMI)
Amps REAL Float Motor Load Current Amps (HMI)
FLA REAL Float Motor Full Load Current Amps (HMI)
KW REAL Float Motor Power Consumption (HMI)
Therm REAL Float Motor Thermal Model 0-100% [HMI]
StartTime REAL Float Time taken for drive to start
InvAmps REAL Float Inverter rated Amps
InvkW REAL Float Inverter rated kW
HSTemp REAL Float Heatsink Temperature C
Speed REAL Float Speed Reference %
MinSpeed REAL Float Minimum Hz
MaxSpeed REAL Float Maximum Hz
NPRPM REAL Float Motor NP RPM
SpdFB REAL Float Speed Feedback RPM
IOImageIN DINT[20] RIO Data
IOImageOUT DINT[20] RIO Data
Hello Guys ,
thanks for your interest,
here below the initial structure data i've built:
Name Data type Description
IN_FB BOOL Binary Input feedback motor running
IN_TH BOOL Binary Input motor overload
IN_ONOFFLOC BOOL Binary Input local hand-off-auto (auto=1)
OUT_MLINE BOOL Binary Output motor run to starter
SIM_ON BOOL Binary Simulation on
EN_MOD_SEL BOOL Binary Enable mode change
AMM BOOL Binary Automatic mode status
AUTO_REQ BOOL Binary HMI Automatic mode request
MAN_REQ BOOL Binary HMI Manual mode request
CMD_STOP BOOL Binary HMI Manual stop request
CMD_Start BOOL Binary HMI Manual start request
SEQ_STOP BOOL Binary Auto/sequence stop request
SEQ_Start BOOL Binary Auto/sequece start request
ALM_WORD SINT Binary Alarm word
FB_ALM BOOL Binary Feed back alarm Bit
COMB_FL BOOL Binary Combined Fail Bit
ALM_ACK BOOL Binary HMI Alarm acknowledge
ILB SINT Decimal Interlocks byte (in automatic mode)
IL BOOL Binary Interlock(s) active (in automatic mode)
IL_OR BOOL Decimal Interlock(s) override (in automatic mode)
FB_TIMER TIMER Feedback timer
AUX_TIMER TIMER Auxiliary running/stopped timer
STAT SINT Decimal Status
intern_stop BOOL Binary internal stop bit
intern_start BOOL Binary internal start bit
ons_stop BOOL Binary one shot stop
ons_start BOOL Binary one shot start
this was done according to my little experience and efforts on the subject.This means that there's for sure further steps to take to enhance this work ...
For Alaric,thanks a lot for this informations ,it gives me more ideas about AB drivers..
Any other ideas are welcome
When building your UDT's make sure you understand how all the member datatypes are placed on byte boundaries. For instance building a UDT as:
BOOL
REAL
BOOL
REAL
BOOL
will create a UDT that is 20 bytes long. If however you ordered it:
BOOL
BOOL
BOOL
REAL
REAL
it would only be 12 bytes long. This can make a real difference to memory usage and scantimes if you are doing a lot of parameter passing to subroutines.
If you will look at the bottom of the window in the UDT editor you will see two buttons <MOVE UP> and <MOVE DOWN>. To the left of each member (row) in the UDT editor is a blank square button. If you click this button then you will select that member of the UDT and activate the <MOVE UP>/<MOVE DOWN> buttons. Use the buttons to group members of the same type together. Look right above the UDT members list and you will see something like Data Type Size: ##. As you rearrange the elements click the <Apply> button and note the effect this has on the size of the UDT. Refer to the user manuals about UDTs for more information about optimizing memory when using UDTs. As Philip indicated, its not just about saving memory but also about the impact poorly arranged memory has on program performance
Thanks a lot Alaric & Philip for the precious infos.
i've tried this,it works well.
now i still try to get the maximum needed data about motor control,that means all the I/O,Tags,defaults,parameters...and for this i have to figure out all the possible cases(contactor,drive,soft starter...
After this i'll probably try to find out the simple logic to combine the whole elements in one Block.
Is it a good approach?
Hi, Please help me with this PLC interview question. The logic conditions are if any 1 sensor turns on, motor1 turns on and other motors off...
5,676
I've started writing a program and its a sequence of steps that it will go through. The sequence commands seemed a little complex to me so I opted...
8,761
Hi, my project is to program the motor in a grage door using control relay. The thing is that I'm using only one button to make it goes up and...
23
8,220
Hello i have poblem whit program, i need use 4 ouputs to control motor step left and right, I create program in GX iec developer but his need 8...
2,154
Hi! Can any one help me out on this? I am new to this thing, and I am trying to make a positioning system that has a lead screw whit a 5mm...
2,489
