motor on and off with single push button
saurabh_bmit
Aug 2005
patiala
I'm a beginner in PLC education, struck with a problem. Anyone can please help. The problem is:
I have a single push button. When I press & release it first, motor should start and remain On.
When I press & release it again, the motor should turn off and remain off. And the same sequence to be accomplished every time I press & release the Button.
Please help me in developing a ladder diagram for this. Thanking you all in anticipation.
Cheers,
Saurabh
Google knows good stuff!...
Hey, whadda know?!?! The 6th link of a Google search for PLC Flip Flop is THIS page at Ron's site...
-Eric
Before you get to completing that, I would first try to understand what an e-stop is, and how you would use it.
In order to first get your motor to stay on. Begin with a memory bit. Have the memory bit on a normally open contact drive the motor ouput in an output coil
Turn the memory bit on with input button down and rising edge, to set the memory bit
Resest the memory bit if it is on, the button is down, and another rising edge, or off and falling edge.
This should probably be the easiest thing you will ever do in plcs
In an industrial application, you are so right.
In a school setting, sometimes understading the first three rungs of logic is overwhelming.
So, I would recommend getting the motor to start and stop, then work in the e-stop.
If our student doesn't understand e-stop, or emergency stop, do a search for either, and a lot of threads will pop up.
regards.....casey
it depends on
use this small code
a i0.0
fp m0.0
=m0.1
a m0.0
an q0.0
s q0.0
r m0.0
a m0.0
a q0.0
r q0.0
take care for this (r m0.0) other wise this will nort work
Assume your pushbutton is digital input1. connect your input1 to a counter with counter value as constant 2. connect output of counter to comparator to check whether input is 1 or 2. if 1 then put on a digital output1 for starting a motor else put off digital output1. Also counter should get a reset. I hope this will solve your problem.
saurabh_bmit,
What everyone is saying is that this exact problem is a typical one and has been discussed about 283 times here at this site. Go to the top of the screen, click "Search" enter "toggle" as a keyword, press search, and you will see at least 283 different posts with solutions for different models of PLCs.
I think the most eloquent solution to this problem I ever saw was posted by S7Guy about 4 months ago. It was using S7 and involved the Xor function.
I think it was only three lines long...
We should run a book of dates on when and where the next one of these questions will appear... I'm going for August 14th around four o'clock... :)
Have a look at the Omron one posted above. 1 input (rising edge) a keep (latching) relay and one contact in the reset line. That has got to be the easiest one I have ever seen.
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,043
This is the motor nameplate from one of the powder hoist motors on the USS Texas an older generation battle ship, built in 1911-1914 ish. The...
295
Im trying to diagnose a loud vibrating/humming noise coming from my companies Kollmorgen Cartride Direct-Drive Rotary motor. The motor is being...
604
hi guys i have a problem, i have five motors and my coustmer want me to start the motor at random sequence and stop the motor in the same sequence...
2,028
I'm sorry to bother you guys, I have been battling this random issue for weeks. We have 14 - Kinetix 6000 drives. When the operator sometimes...
4,179
