motor speed program
sas11
Mar 2008
Virginia
36
Hello,
I am on a mission to build an annealing machine for reloading brass. My experience with PLC's is limited. However I am a HVAC controls tech so I know outputs and inputs.
My plan is to use a click plc model? The beginning design will be a 12vdc motor that I can control the speed with a Knob and a linear actuator?? to stop for a settable amount of time, then release the cartridge.
Any thoughts or help getting started would be appreciated
SAS11
What type of DC motor are you using? With a permanent magnet DC motor you change the speed by changing the voltage.
The term "linear actuator" generally refers to something like a pneumatic cylinder that is used to move something along a linear path.
The motor that I picked out has an optional speed controller 6-30volts. As far as the actuator I planned on putting it on a u shaped swivel.
What reference does the speed controller take. You can set your speed with analog IO. 12V isn't really a common PLC voltage.
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
744
Studio 5000 & PF 525, Ethernet Comms, Encoder FB, Using Motor RPM as speed reference I'm trying to figure out how to send a speed reference in...
947
i am going to ask a selly question : is there a parameter that might change the speed of the attached motor at a givin frequency either up or...
2,409
Hi Members, Currently, I'm working with Motor Generator speed measurement. Just wondering if possible or not my integration system for speed...
1,950
Hi All, I'm based in the UK and usually when I set up a Powerflex Drive I enter the Motor Nameplate Details from the motor that match our supply...
1,692
