Motorola Moscad
abishur
May 2012
Texas
47
I got my hands on an old motorola Moscad. I can connect to it, but I don't have the password so it won't let me read the hardware, or view the programming software or even upload a blank program to the PLC. Does anyone know how to reset a Moscad back to factory defaults so I can do anything with this PLC?
If you have a copy of the program and config you can blank out the PLC and reload the program with your own password. But, if it is communication with other PLCs in the same network it will not communicate with them anymore until you figure out the password due to that being the first level of security on these particular devices. Depending on who programmed it last the password is more that likely "motorola".
I was updating my FIU (Master?) to try and improve radio communications. But I also ended up deleting the Modbus configuration on Port 2, so my...
1,467
Hi..anyone can help how this MOSCAD heartbeat works?..thanks
1,617
Hello guys, I'm working on a water reservoir job and the client wants to extend the existing PLC configuration so he can monitor additional...
2,073
I'm a newbie with the Motorola ACE3600 and have an issue with data retention. These RTUs have a battery backup but if the AC is down long enough...
6,427
Hi, I'm testing communication between Motorola Moscad (Modbus master) and S7-200 (Modbus slave) with modbus communication but still no...
2,875
