Moving PV+ program
cornbread
Feb 2007
madison, indiana
407
Our IT folks have forced us to put our PLC's and PV+ behind a firewall. I need to transfer my PV+ programs from my laptop to a new computor behind the fire wall....my question is what is the easiest way to do this?
1. Use App manager to create a .apa back up file and then restore that file to the new machine?
2. Use the transfer utility and perform a upload?
3. Can I copy the entire directory over?o_O
Definitely #1.
The Application Manager is the only good method for moving FactoryTalk View projects from one computer to another.
Definitely #1.
+1 on this. Copying and restoring .mer's is always a dicey proposition at best. Seems like something always gets lost in the conversion.
Under App manager
pick resyore application
Select the app to be restored
Do I pick
Restore the FT view ME Edition application or
Restore the FT view ME Edition application anf Factory talk
local directory
We did some trials with uploading the PV+ via the transfer utility... save the mer file and the used the application manager to restore the runtime application.... Seems to work..so far.
Good Afternoon , I know this question was asked back in June. I am doing the process described by OperagHost below , but I don't understand...
5,067
Is there an easy way to move Program Tags to Control Tags. I know I can export and import tags, but can you import exported program tags into...
13,573
I'm a Siemens person, and this is one of my first AB programs. The customer wants everything programmed in Ladder. I have a lot of data (3...
232
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
255
Hello, i am a beginner with a Siemens Logo 8 PLC. I would determine the direction of an object if it passes a whole cycle of 2 input sensors. See...
196
