MsComm Control in Citect
captain_is
Mar 2009
Romania
57
Does anyone know how to use the MSComm control with citect to send values over the serial port?
I did something like this in Cicode:
FUNCTION
test()
_OBJECTSetProperty(ObjectByName("AN37"),"PortOpen", 1);
_OBJECTSetProperty(ObjectByName("AN37"),"Output", 0x52);
END
And i associated this function with a buton, but i see nothing happens.. i don't use ComWrite function because i need to send hex values not ascii..
Any ideea for my problem..
Thanks in advance!
FUNCTION
test()
END
Thanks in advance!
Sorry i didnt see this before.
You can send hex values over ComWrite(). Just use StrSetChar() to build up your databuffer that you pass into ComWrite().
eg
STRING senddata;
StrSetChar(senddata,0,15);
places x0FH into the 1st byte on the Senddata STRING buffer.
Hello Fellow Rockwell Users: I'm new to the industry but I've done some development using the MSCOMM activeX control in VB6. I'd like to use this...
5,269
Hi all, I am setting up a mscomm on wincc,however the mscomm needs to run all the time regardless to which screen i am on as it will then call...
2,473
Hi all, has anyone used MSCOMM in VB6 with OPC ? I have a serious issue with KEPServerEX4.0, VB6 and MSCOMM (Microsoft Comm Control 6.0). I'm...
11,900
Hi I want to use Visual Basic as a front end to talk an Hitachi EH150 PLC (yes an Hitachi PLC !!!). Can anyone point me in the right direction on...
2,239
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
58
