Factory Talk View SE and MSCOMM
mspath
Mar 2004
Hello Fellow Rockwell Users:
I'm new to the industry but I've done some development using the MSCOMM activeX control in VB6.
I'd like to use this control in Factory Talk View SE ("FTVSE") to move data to tags on an event from the serial port.
As I read the FTVSE documentation it states: "FactoryTalk View supports the use of windowed ActiveX controls only. You cannot use
windowless ActiveX controls in an FactoryTalk View graphic display"
Does this mean I cannot use MSCOMM in FTVSE?
Any suggestions on how to get data from a serial port to our FTVSE app would be appreciated. Thanks!
142
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
335
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
298
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
606
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
375
