MSG from CompactLogix L35E to SLC 5/05
skyman434unme
Jul 2010
Central Pennsylvania
I am attempting to program a "SLC Write" Type of instruction in a MSG from an L35E compact Logix controller to a SLC 5/05. The best I can do is get an extended error code 0204 "Unconnected message timeout". LocalENB, 1, 192.168.3.7 is the communication path which is correct, and the PLC's are both on the 192.168.3.x class C network. Communication method is "CIP".
Anyone have any ides?
Here's why: CIP Paths are pairs of Ports and Addresses.
From the communication module's perspective, Port 1 is the backplane. Port 2 is the first network port.
Port 2 is the only network port on EtherNet/IP, ControlNet, and DeviceNet modules.
For multiport modules like the 1756-DHRIO and the small 1769-L31 controller, the two ports are Port 2 and Port 3.
I've always wanted to know what that "2" was for. Thanks Ken.
Customer has a radio telemetry master using a Compactlogix L35E Serial port set up as DF1 Half Duplex Master and has been adding remote stations...
2,022
I have an issue with the communication trough the MSG instruction, I want to send information to a printer from a 1769-L35E, I have configured the...
17
16,146
Guys, I cannot find any specs or recommendations for Explicit Messenging for Compact Logix L35E. I did a job recently with an L35-CR and ran...
1,896
Does anyone know if is possible to read data out of a ProfaceHMI/PLC into a CompactLogix PLC? I have a bunch of OEM machines on our plant floor...
501
Hey Guys Having some trouble again with message path, I thought I had these figured out but I've not been able to get this one working. I...
611
