CompactLogix MSG Path
eight_bools
Apr 2019
Oklahoma
71
Hey Guys
Having some trouble again with message path, I thought I had these figured out but I've not been able to get this one working. I attached a diagram of what I am trying to do, and my best description of what I have.
I'm trying to MSG from a CompactLogix to CompactLogix through a ControlLogix backplane. I called Rockwell tech support and the guy I spoke to was not familiar and wasn't sure if what I was trying to do would even work. He suggested that I use the PLC in the ControlLogix rack as a data buffer.
Just wanted to check to see if anyone had experience with this, it seems like it should work but maybe its not possible.
4,192.168.1.10,1,0,2,192.168.0.20
4 - CompactLogix A (Port A2) - PLC A
192.168.1.10 - EN2Tin ControlLogix - Rack C
1 - Backplane - Rack C
0- Slot 1 L81 - Rack C
2- Ethernet Port
192.168.3.1 - CompactLogix (Port A1) - PLC B
I can't imagine why this would not work. What error are you getting on your message instruction and how did you set it up?
Well it seems like I always miss something super simple, I assumed it was the message path since I have struggled with this before. The error message was just a "General Error"
It ended up being a data type miss match between the processors. Trying to read a DINT[10] into an INT[10]. I guess on a positive note, I had the communication path correct so I am learning from my mistakes.
Thanks to everyone!
Glad to hear it worked for you!
Funny, I have seen a slew of data type mismatch mistakes of late, must be something in the air :p
Does anyone know if is possible to read data out of a ProfaceHMI/PLC into a CompactLogix PLC? I have a bunch of OEM machines on our plant floor...
493
I'm working on a project currently that is requiring me to log a username and a and number. I need to MSG a string file, the username, and an INT...
2,074
Hi all I'm trying to setup a MSG connection (which I'm not familiar to) between a CompactLogix CPU (L310ER) and a Micrologix 1400 CPU. At the...
810
Hello Everyone, Can two PLCs on two different subnets pass data via CIP MSG Read Instructions? I would be using the HMS Fl3xy NAT 1:1 feature to...
2,472
Yesterday I was working with an Allen-Bradley Controllogix and a Compactlogix. I was using a MSG instruction to read from the Controllogix via...
1,127
