MSG Read - LGX5K - SLC
TerriLaf
May 2006
Florida
20
Hi All,
I am having some trouble configuring a CIP message read on the logix 5555 to read data from a SLC 5/05. They are not directly connected. They are connected via a ENet switch.
I have tried a couple of examples that I have found and even tried some that I have used in the past. Problem is that I just don't use messages enough.
Ok.. So long story short. I want to use the 5K to read from the 5/05.
The ethernet module is located in slot 2 of the 5k rack.
The address of the SLC is 192.168.1.1
My path currently looks like this...
R00S02_ENBT, 2, 192.168.1.1, 1, 0
The error I am getting is 16#0004
The error Path is: the path noted above
Error Text: IOI syntax error
I am looking at an integer value in the SLC (N7:5)
The local logix 5K tag is setup as a DINT (I get the same error if setup as an INT).
I'm sure it's something minor that I am overlooking. Any help is appreciated.
Thanks!
o_O
What is the extended error code?
Is your message a "SLC Typed Read"?
Your path "looks" like it has a couple of extra points on the end. My Message paths stop after the SLC IP address. (I used the browse feature to fill in the path info for my compactlogix to 5/04 read via NET-ENI, so I am not an expert on the path notation.)
And, your data types must match, so the type needs to be INT.
Thanks Ron. Though I thought I had tried this setup before, I must've configured something incorrectly along the way.
This setup works perfectly.
Thanks again!
TLAF
Does anyone know if is possible to read data out of a ProfaceHMI/PLC into a CompactLogix PLC? I have a bunch of OEM machines on our plant floor...
501
Hello Everyone, Can two PLCs on two different subnets pass data via CIP MSG Read Instructions? I would be using the HMS Fl3xy NAT 1:1 feature to...
2,478
So I have a micrologix 1500 on network through an ENI. I need to read an integer from it to my SLC5/05 so I can stop pumps when the remote tank is...
2,051
Yesterday I was working with an Allen-Bradley Controllogix and a Compactlogix. I was using a MSG instruction to read from the Controllogix via...
1,135
The Ethernet has 3 pieces of PLC5 processors (PLC5-40E), for easy explanations, we name A,B and C. All pings are OK and RSLogix5 can connect all...
4,925
