MSG struction between ControlLogix And CompactLogix
b_e33
Mar 2013
lolo
59
i using MSG function between the controllers but he write me an error messege
that the port is bad
what i`m doing not ok
the ethernet module is 1756-enbt (connected to the controlLogix chessis)
i set the function in the controlLogix
see at the pictures
realy need help
what i need to do to fix the connection
now it ok and i get a start , but after second i get new error 0004 , he write me in the error text line : |0| syntex error
what is the problem?
Your "MSG command" ladder logic is not quite functional within a Logix system.
Delete all the "Rung-Conditions-In" instructions and replace them with the ExpconWrMSG.EN XIO (normally closed); you could add your Test_MSG XIC(normally open) instruction in a Logical AND (Series)within the MSG control rung for user On/Off switching purposes, however, as a rule of thumb, within a Logix system, a MSG instruction will be serviced at all times when it is not enabled.
hi,
i m using Allen bradely slc 500 PLC, we have connected one barcode printer from its cpu rs232 port. bt from today morning it is not working. can port be repaired ??
109
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
373
Hello Friends I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP. Now, I am trying to...
290
Can Anyone tell that How Msg Instruction comes under Unscheduled communication and How System Overhead time slice(SOTS) function connected to it...
972
Studio5000, V31 I'm Messaging a MassFlow Meter, specifically to pull the Engineering Units (units of measure) for 6 instances. Basically, do I...
1,209
