Multi loop process controller
DST1
Feb 2009
Indiana
27
Does anyone know if there is a multi loop process controller out there that will accept the PV over Ethernet/IP?
We have an extrusion machine with 40 zones (11 of which are heat/cool) that are controlled individually by a mix of Barber Coleman and Eurotherm controllers. They are not fitted with any sort of comms card to interact with an HMI.
My objectives are:
1. Replace individual controllers and make SP changes at the HMI.
2. Clean up TC wiring with remote I/O at the machine (plan on using AB Flex I/O IT8 modules)
3. Read amp draw from zones for alarming/shutdowns.
4. Use existing SSR's.
I've done another one of our machines using ComplactLogix with Flex I/O, but without the capability of monitoring the load. I'd like to avoid adding all the additional analog I/O if there is a controller out there that will do what I'm needing.
danw, I did mean PV. I want to eliminate the long thermocouple wiring runs to where this controller would be located. I was thinking about using Flex I/O like in my other installation to gather the temperature reading into the PAC. Then, I would send the PID controller the PV over Ethernet/IP.
I don't know if it's possible, I might just have to deal with the thermocouple wiring. This would eliminate the need for the Flex I/O as well...
Hello, I had a question about benchmarking the Rockwell FactoryTalk View SE software. I've installed in the neighborhood of 30 different...
285
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
136
Good Afternoon , I'm sure there are many Ishida Muti-Head Weigh Systems . We have a Ishida CCW-M-214W Multi-Head system . We are...
547
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
514
