Multi-master communication
selvaraj
Jun 2012
Bangalore
Hi to everyone.....
Am using Messung system's Nexgen5000 PLC and their smart touch 60B-E HMI. Now am trying to connect two HMI's
with a single PLC. Normally, 2 HMI's are to display the production status of 2 different CNC machines. Out
of that 2 HMI's, i need one HMI should act as a master and it should contain the overall production status
with it. How can i achieve this ? ?
In these HMI, there are two communication ports. COM1 is 9-pin female port and COM2 is 25-pin female port.
Now i connected the PLC to COM2 of HMI1. The COM1 of HMI1 is connected to the COM1 of HMI2. But i couldn't able to
communicate ? ?
When i enter the value in HMI1 for the first time, it is updating the value in HMI2 also. But from next time, it is
not all updating the value even if i change the values in HMI1 ! !
pls help me. . .
Dear All, some how we lost the USB side of the cable of our PPI adapter and now we don't know the USB pin configuration inside the PCB part a 4...
5,510
Hi. I've got: CPU 317-2 DP / 6ES7 317-2AK14-0AB0 CP 342-5 / 6GK7 342-5DA03-0XE0 CP 343-1 / 6GK7 343-1EX30-0XE0 Basically S7 gathers a lot of...
2,616
I am user of S7-200 CPU-226. PPI Multi-Master cable is not listed in PG/PC interface menu on my laptop software in STEP 7-MicroWIN V4 SP3. Can any...
1,669
hello, if i want to extend(make the extended RS-232 by my self) the simatic s7-200 RS-232/PPI multi master cable on PC(RS-232) side, is right if...
1,576
Please help me. The DB9 on my USB/PPI converter was dammaged. I need to know the wire color to pin, with this i can install a new DB9. Thanks
1,592
