ask: i want to extend the simatic s7-200 RS-232/PPI multi master cable
albert_r
Jun 2012
surabaya
hello,
if i want to extend(make the extended RS-232 by my self) the simatic s7-200 RS-232/PPI multi master cable on PC(RS-232) side, is right if i used only the 2,3, and 5 terminal on RS-232?
thanks..
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
979
We are to develop a first application in Codesys. It will contain motion (Softmotion) with drives on Ethercat (CSP mode). Off course there will be...
920
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
855
Hi guys.. I am using Vijeo Citect 7.4.. I am doing a function inside a function.. What I want to do is I want to put a function to sleep but want...
1,445
I am working with a 1768-ENBT and I was able to connect to it through my laptop. My laptop IP is 192.168.1.10 subnet 255.255.255.0 and the PLC...
1,586
