Multiple Micrologix behind a router
I am going the VPN route, but just out of curiosity in case this may help on another job, what is the other way? I know I can forward port 44818 (which is not changeable in RSLinx) to a specific PLC, but without changing the port forwarding setup in the router each time I need to access a different PLC, how would you do it?
in your case the only way to do it would be to change it every time.
My main question is what hardware do I need to make the connections. Is a 1761-NET-AIC module required? I'm going to use channel 2 (the 9-pin...
2,848
A deep thinker engineering question that I pose to you. I have 6+ machines with basically the same PLC program (Micro 1100 with 4 cards). My...
2,861
Hi all, I would like to read ASCII weight from 2 scales into a single serial port on a MicroLogix 1400 using RS-485. I haven't seen any posts on...
3,110
I have a folder with about 50 of the same plc program file with the same name. I don't know which on the machine needs. The date created is the...
2,698
Hey Everyone, I recall seeing multiple threads a while back regarding needing a certain version of RSLinx to establish communications for a...
1,650
