Multiple PanelView Plus' - One PLC
In our application, we had 3 panelview terminals on a slc 5/05 plc. the only different was the control screen addresses and the main screen. same application. we did not want all the terminals to access different parts of the line, we limited it to specific areas.
james
One option is to set a windows login
Different access for different operators
Set up the auto log off
only select operators have the ability to make changes
i have had several projects where that was requested by the customer
it worked well
If both HMis have the same runtime, can a button be added (using different tags on each PLC) to activate one panel and inhibit the other and vice versa to avoid the case of two operators using the panel at the same time?
I made a PV app before that used the ActiveX ME IPInfo to get the PV IP address. Then used the ActiveX ME MacroMultiplexer to enable/disable parts of the application if that PV was not in the same area as the machines.
Can anyone tell me if it is possible to use Factory Talkview ME programming software with a new Panelview Plus HMI to read tags from multiple SLC...
1,640
I've never tried to do this before, and I've thought of a few possible solutions, but they all feel like kludges. I have a control system...
6,881
Working on a project where we would have two pieces of equipment (say A & B) each with a 1769-L30ER and a Panelview Plus 6 600. There is also...
2,397
I was hoping to find out if it is possible/advisable to use multiple panelview touch screens with machine edition to communicate with a single...
2,891
I have two PanelView 1500 Plus HMI's next to each other both communication to different PLC's. If i copied the program from the one onto the other...
3,648
