Multiple reference frequency to Yaskawa VFD
neilm
Feb 2019
Jackman
28
Good morning,
A Yaskawa A1000 series VFD is controlling a chain at the ref. frequency 1 (let's say 70 Hz) as its default. In winter months, a change in selector switch's position changes it to ref. frequency 2 (let's say 30 Hz). I checked the B1-01 to be 0. This means the digital operator and not analog input terminals. Is there a way to provide a 3rd ref. frequency as a digital output from my PLC? How to prioritize among them?
Thank you
The A1000 is flexible you can use the programmed inputs to select B0 B8 frequency reference or you can use either of the analog inputs. you can select them using the inputs.
they also have a ethernet option or a digital reference input option card.
download the used manual.
Hey Everyone, I recall seeing multiple threads a while back regarding needing a certain version of RSLinx to establish communications for a...
1,664
Hey all, I am working on a project and i want to use Allen Bradley Micro850 controllers. This model has ethernet ip functionality. So the project...
85
Hello, Anyone have a nice working solution they can share where there are a handful of engineers that work on one project. I have setup 2 SEL...
218
Hi, How to get data from multiple Mitsubishi Q03UDVCPU into master PLC Q03UDVCPU through QJ71E71-100 ?
62
Can I connect two A-B Panel View 7 to a A-B PLC. Same graphics etc. One on the local control panel and the other Panel View 7 in a remote control...
77
