Murr IO link, zeroing Magnetic sensor MSA213K
jakesheehan
Nov 2023
wa
I have a murr IMPACT67 Pro E DIO8 IOL8 M12L 5P and a Magnetic sensor MSA213K. connected to a L18.
encoder is connected to port 0 and I am getting values back.
the msg instruction is faulting with a class or instance not supported.
attached are the error/msg setup, notes on setup, what I'm sending.
thanks.
Can anyone elaborate on the differences on how these technologies work? It sounds similar, but IO Link adds the addition of sending parameters to...
3,260
Hoping someone can point me in the right direction here... Studio 5000 v33.11 We have a Murr IOL master block (#55144) configured as an EtherNet...
2,110
Hello all, I am working with the above stated hardware for the first time. Has anyone used a EtherCAT Cube67 with Sysmac Studios before? If, so...
1,704
Hello, I was looking for alternatives to using the standard AB Local IO and I came across the Cube 20 series from Murr. I know the response...
2,266
I'm trying to add a MURR I/O module to an existing MURR network. As you'd expect, the input/output sizes change when the new module comes online...
1,862
