My Rslinx is running but I don't see it
showshocka
Mar 2011
USA
510
My Rslinx is running but Can't pull up the interface, even after rebooting and selecting to have all of my Icons in the task bar. It's Running because I can log on to the PLCs through my wireless Ethernet connection. and btw it is not the blank spot that you might notice in the task bar...
might be running as a service
It's actually even easer than that; from the Start menu, navigate to the Rockwell Software submenu and launch the RSLinx Service Control Panel. Because Windows 2000 hides seldom-used items in the Start Menu, this little utility is easy to overlook.
The RSLinx Service Control Panel will let you simply uncheck the box that tells RSLinx to run automatically as a service.
http://www.plctalk.net/qanda/showthread.php?p=11675#post11675
Hi all. TL;DR at the end. Had a situation last week where I needed to connect a workstation running RSLinx to a running PLC code, just to extract...
12,732
Hi guys, I was trying to configure the drivers. Configure drivers window showing AB_KT-1 DH+ Sta:0 addr.D000 error but status showing...
1,714
I work at a manufacturing plant that has most everything running on some sort of PLC. The controllers are linked by a "data highway" so they can...
2,730
All, I recently decided to install my Rockwell apps onto my windows 7 environment (previously running XP in a VM). After I installed everything...
34,191
Hi Everyone. I am buidling a VB application which uses DDE via RSLinx to communicate to a processor. I would like to start RSLinx minimized and...
13,976
