NAT Device Options
Dryhops
Jan 2018
California
90
Our facility has a number of machines that utilize NAT devices to connect to the broader industrial network. Specifically, the Allen Bradley 9300-ENA.
We are adding more equipment that I would like to set up to mimic this. Are there any alternatives to the 9300-ENA, or do I need to use this for compatibility reasons? It is impressively expensive for something that performs a glorified find and replace.
Thanks for you time!
How many devices are you trying to map?
Looks like your 9300-ENA will support 128 translations. I use the 1783-NATR in my facility, but that only supports 32 mappings.
This is actually a fairly small panel in terms of devices I need to map. It will be a tank farm with 16 tanks. I only have 2x 1734-AENTR's and a 1756-EN2TR that are addressed. In the future there may be 1 or 2 more addresses mapped.
I'm really trying to adhere to the original design of the facility, where each tank farm is a self contained network, connected to the larger industrial network via NAT. However I'm sort of on the fence as to if the benefits of this modular setup are worth the cost.
Hello, I have a NAT device 9300 ENA that I can ping successfully but can not see it in RsLinx. I need to set a private address for an IO link...
1,552
Hello, does anybody know if it is possible to produce and consume tags between processors that are connected through 9300-ena devices on an...
2,738
I know this topic has been brought up a few times, but i had some specific questions. I have installed several 1783-NATR devices and they have...
315
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
201
Hi Guys I am looking for some help to get communications going through a Stratix 5700 with a NAT rule in it. I did not set the stratix up but I...
1,008
