Nc contact of proximity sensors
This probably started in the days of relay logic as it might be convenient to have a N/C contact on the sensor so that the logical 1 is when sensor does not detect anything, like all buttons/sensors etc. it is sometimes convenient to have a N/O + N/C contact for different circuits. also this is the equivelent of light on/dark on sensing. so if you need a signal (light on)when no object is present use N/C or N/O when dark on (object present).
Something also to keep in mind, if you decide to use a solid state device, is do you need a sinking or sourcing device. This is dependant upon what type of input card you are using, be it a sinking or sourcing.
I often see them used as overtravel limits connected to servo drives. That way, if a wire breaks, an overtravel fault stops the drive.
Paul
I have seen NC prox switches fail in the closed direction. For overtravels, I always recommend a real limit switch with force guided contacts. (The customer doesn't always use this but it's what I would recommend).
I would like a NO VOLTAGE, DRY CONTACT proximity switch. Give me one now! Or please direct me to a website where I may purchase one or make...
5,182
Good day all. I would very much like to have a dry contact (no voltage) proximity switch/sensor. I know that such a device exists. Does anyone...
3,900
I am stuck on fail ctrl error 1013 cannot get IP nor can do firmware update need help pls urgent
174
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,302
Hello all... I'm looking for a 480v 3ø 25+ amp Solid State Relay to replace a mechanical one beating itself to death keeping temp in a heating...
1,976
