Need a little help
2bru
May 2010
ohio
Hello everyone,
I want to know what I am doing wrong when trying to upload a program from a pv+1000 on a dh+ network. The 5/04 and HMI or talking just fine and I can get program from the plc with rslinx. But I can't upload from panelview with factorytalk tranfer utility, it thinks about for a long time then tells me the source selected is not a valid device.
for most PanelViews the easiest/best way to upload/download is through a "straight-through" serial cable (DB-9 pin) ... we can't tell for sure whether this will work with yours until you give us the complete model number ... this usually starts with 2711- or something along those lines ... note that there are MANY different PV-1000 models and there are MANY different methods of communicating with them ...
so ...
post your specific information on the "real" Question and Answer board and someone will be along soon to help you out ... (this is the practice area and most members don't look here for questions) ...
and welcome to the forum ...
Hey guys, I have a client that has a v-notch chlorinator that doesn't run off a 4-20mA loop, it instead has two discrete inputs that drive the...
1,886
I was given a small PLC project from my dad for his company and I have ran into a few problems. I have found it necessary to use an output in my...
3,880
I am using a compactLogix PLC. We built a conveyor system now we have added an end of line sorter. Yes an add on and no one has thought of how it...
19
7,566
I need to use a contrologix 1100 to index a stepping motor. I will be using a IMS (intelligent motion systems) stepper driver and using the 1100...
1,182
to get straight to the point im working with a PLC-5/20 programmable controller, is mounted on a 1771 a3b1 12 slot chassis. it has 1771 ofe and...
8,311
