Need guidance for a programming technique
TL140
Jun 2014
South Carolina
152
Hey guys, I would like to ask some advice.
I am working on the LogixPro bottle line simulator and I am having trouble figuring out the logic in a specific way I want to do this.
I can get the simulation running good but I am doing this to clean up the code for a more professional manor and to use with other applications as well
I want to use the first limit switch and the first switch only. Once the switch is activated, have a 2 second timer where the first part idles. Once the timer is up, activate the conveyor. The conveyor stays on while the bottle is actuating the limit switch, stays on when the limit switch turns off (bottle moving off of it), and then the conveyor motor stops when it receives a signal again from the limit switch. Then the Timer activates to wait, and the process repeats.
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
211
So, my job is pretty much giving me a PLC lab to train with. I just finished up some basic analog signaling and processing using a process meter...
8,991
I am working on an application in which I will need to compare two PNP (or NPN) pulses, each of which coming from light sensors at two separate...
2,580
Hello everybody. I am into technical marketing of various automation products except PLC's. Recently I have been given the responsibility of after...
3,592
CheezyMane13
C
I am an electrical engineer working for an A-E which designs all sorts of facilities. I’ve had all kinds of experience in lighting systems, fire...
5,460
