need help direct logic 06
AGENTTINFOIL
Jul 2005
Louisville, KY
222
I need to write a program but not sure how to do what I need It should be simple all I need to do is count parts with a photo eye I assume a pulse signal as the input and my output needs to control a pneumatic valve. help anyone
I'm assuming you are either a student or a person who wishes to learn how to do a relatively simple task using a PLC, specifically the DL06. You have identified some aspects of the task. The external items - a photoeye to sense the part and a pneumatic valve as ouput. You have also gone a long way toward identifying internals of the PLC - some method of counting and some method of controlling the output in time (pulse).
So next get the DL06 manual. It's free online. Skip the beginning and go right to the introduction to ladder logic. Write a simple program to turn on the output every time the photoeye sees a part. It's not what you want but you'll have the hardware in place and working.
Next, go to the sections on timers and on counters. Read through these carefully. Modify your program so that the passing of a part increments a counter. Then further modify it to reset the counter when a specific number of parts have passed by.
Finally, let the reset of the counter start a timer. While the timer is timing, fire your output (pulse).
Taking it in steps like this will teach you the most about the system and you'll end up with an incredible start into this type of control.
And come back here telling us about your initial sucesses, even "I got an output to turn on when the photoeye saw a part!". The members here will help to guide when you hit some tough concepts without hindering your learning by giving too much help.
(In case I am mistaken and you just want someone to provide a working program right now (and you aren't a student), there are several professionals who will be willing to do that for a negotiable fee.)
Agent Tinfoil,
Here is a ladder to get you started. Where the black box is, you need to add something.
bernie thanks for your help, and yes i do want to learn this is my first project and im learning fast, still trying to fill in the blanks but its coming along thanks again for the very useful info.
This is an older system. My supervisor managed to let the magic smoke out of two of the comm boards in the ServoDrive controller, after replacing...
1,339
Well I Believe I Have Figured Out The Counter But Now Im Not Sure How To Start Writing A Program. I Have Read Alot On The 06 And Ive Filled In The...
5,568
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
114
71
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
393
