Need help with making 'integrator' function block?
IanJohnston
Jun 2003
Hi all,
This is tearing my hair out!
Mitsubishi Q series PLC, Mits GX IEC Developer.
I have an analogue input I'd like to have 'damped'. Not simply turning up the averaging but more like an Integrator function block....thus the response of the final value is still fast, but on a big input value change, instead of jumping directly to the new value it will 'ramp' to get there.
It seems there isn't a built in Function or block I can use, and I've tried building my own using a 'ramp' block etc.....but it just don't work quite right.....requires too much stuff around it to control.
Any ideas, sample code etc etc.....highly appreciated.
Ian.
Thanks, I'll look at that low pass filter......
.....in the meantime, Tom's equation works pretty good on GX IEC Developer. It near as damn it works like an Integrator which is what I originally wanted.
Ian.
I'm new to this site. Have been an industrial electrical tech most of my life. Plenty experience around PLC's, just not had a whole lot of...
3,059
Hello all, I've got to make a totalizer for our digester acid fill using rslogix 5. I have a flow transmitter scaled for 0-16000 LPM using a CPT...
5,236
i have a allen bradly plc in my class room at the college im going to. i have board with 7 lights and 7 switches on it. i had a program that had a...
17
5,863
96
150
