Nema 4x VFD
No, I have used the Yaskawa V7 Nema 1 drive mounted in an enclsure many times, but I have not used the V74X. Typically, I use the TB Woods X5, but since Woods has been sold to Vacon, I will most likely use the Yaskawa. Also, I checked and the V1000 series does not have a Nema 4X rated drive.
I don't know what your panel material requirements are, ours is stainless steel, but I have used Nema 4X fiberglass panels in the past to house VFDs because the fiberglass panels transfer heat much better than stainless steel or carbon steel panels, almost twice as good as stainless steel. If you can use fiberglass panels you may be able to get by without adding a fan at all. It all depends on the application.
regards
RSL said:
I just looked AB makes PowerFlex Drives in the flange mount configuration.
Is their a fan mounted externally that can/will fail?
RSL
The last several flange-mounted A-B drives didn't even have an external fan. We had some older PF700 drives that had issues with the external fan failing after a year or so. The newer style has a much larger heatsink and no external fan to fail. We've got two panels out now with this newer style, and they have been operating all summer now without any problems.
Joe
Cooling
I use venturi coolers (such as Exair) where possible as they also pressurize the cabinet, but I also mostly work with nema 12 so I've never checked if they can be used for nema 4x. A reasonably sized cabinet can likely handle a 15 hp drive without cooling. You can check using the drive manual specs and this tool: http://tools.hoffmanonline.com/index.html Know this is old but it was high in the search results so thought I'd chime in
RSL
When you buy the Flange Mount version for smaller sizes, the fan on the outside is rated NEMA 4X. On larger sizes where you buy a NEMA 1 drive and a flange mount kit to adapt it, you have to replace the standard fan with a NEMA 4X rated fan, it is sold as an accessory kit. Most people fail to read the instructions to notice that, so the fans fail and they say they are ****...
Good evening gentlemen, I am looking for VFD with NEMA 4x rating. It's a small one, single phase 208/230 input, 208 three phase motor 8.46 Amps...
3,487
I have noticed that many HMI have a Nema rating of Mena 4/4X (indoor use only) Does anyone have any guesses as to what the constraints are that...
1,806
Looking for some explanation/history between North American electrical symbols standards (how they relate, what are the latest, what is the...
1,716
Hello, are there any standards for control wires naming rules? I have to set them up in my project (see pic). What is usually prefix and...
2,238
Looking for a brief explanation for the NEMA MG-1 Part 31 standard for the actual voltage values. In reading many articles I have seen 1488Vp...
1,408
