NETlink USB compact problem
lemur1234
May 2012
Hisa
Hello,
I have the NETlink USB compact. It works perfectly fine when i use it on a Siemens 300 PLC. But it won’t work with the Beckhoff 315 PLC. I guess it could be something with how the PLC is set. But don’t know for shore. Does anyone have any ideas, what I can set to make the darn thing work?
The adapter is EL6731.
Thank you for any ideas. If you want more detailed info I will be happy to give it to you.
I have one MPI/Profibus - USB from Helmholz.
It did work but it had some hickups if I did not start things in the proper sequence.. Had to reboot and start software in correct sequence.
Therefore I changed to MPI/Profibus - Ethernet and that one has worked without any issues... Works perfect...
Not much help, except I had the same issues and rebooted
Brg
Andreas
Well,
This was Simatic Manager, which you already have working, but when I had the problem I am certain that I did the following:
1 : Boot the maching
2 : Start Step7
3 : Set PG/PC Interface to NETLink USB
4 : Insert the device into the USB port
brg
Andreas
Hi I wonder about som technical aspect regarding netlink communication to CPU 314-2C DP. When i set my adress 0 in PG/PC interface (the same as...
1,352
Hi All, I'm using NETLink PRO Compact by HelmHolz to connect a PLC Simens s7-300 and it works good. This means I can go online on to the plc and...
3,839
Hello all can any one tell me what is the difference between 1.cp 5512 vs netlink pro? 2. Which is more superior? 3. How netlink differ...
3,571
hello problem on Netlink Pro Eth. i connected the Netlink to Switch and from there to 2 PCs. i am able to get the data on 2 PCs. Now wants...
2,443
I bought the netlink adapter MPI-LAN from Hilscher. This together with the KepServerEx for Siemens. I can configurate the KepServer, i can put an...
5,486
