network parameter fo A3A cpu
mouhab_ah
Jan 2014
Egypt
20
I have a A3A mitsubishi cpu plc master and local connecting through coxial cable ,
these two plcs exist in printing machine and the master one had lost his program , i found a program written on papers so I rewrite it using gx devoloper.
now i face a problem with network parameter , beacuse the master unit is also connecting to 6 remote i/o module through twisted pair cable .
i will upload the diagram of the newtork for both plcs and with the remote i/o unit .
and when i upload the program with out parameter it give me an alarm in plc link par. error
please help.
Currently I'm using CC-Link modul QJ1BT11N as master station. The CPU I'm using is Q Series CPU, Q02(H). The problem is, I don't understand how to...
2,798
Hi All, I need some help here, I'm trying to set up this CP5512 adapter to communicate with the Siemens PLC, all I left is to set up the...
3,797
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
156
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
220
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
181
