Network questions (wincc flex runtime)
userxyz
May 2002
any
2,768
In 2 weeks I have to start-up a new machine.
In test:
I have WinCC Flex Runtime on a PC. I save recipes on that PC in csv format. The MP277 panel is reading and writing to csv's on my PC as well. The wincc flex is connected via a swicth to the PN port of my 317 cpu.
The MP277 is communicating over profibus for critical data and over ethernet for some simple databasing.
Start-up:
In an office PC I will install flex runtime. The machine has to be connected to their ethernet companynetwork. I will choose IP's in their range. The WinCC Flex should communicate this way to the PLC. The MP277 has to be able to write and read csv's on a server location.
Can I have troubles to start this up, anyone with experience on starting up with a strange network ? I'm a little affraid that I will loose time to make this connection...
What should I take in care ?
I dont forsee any issues, get their IT to allococate fixed IP addresses for your gear
okay
Same thing for the server ? I have to write to csv's and read from them on a server, can this be seen as a remote PC with a certain path like //Servername/folder/ ?
One other thing, with My panel I read and write to shared folders, when I boot the machine, the panel allways asks a user login for the shared folders. This will not be a problem either ?
This is the way easiest approach. You dont have to worry about DHCP and/or routers.
I cannot imagine you will have any problems, when there are fixed IPs are in the same range, and the addresses are coordinated with your customer.
There was a FAQ on Siemens Support about using DNS names rather than IPs. I think that the login was also mentioned.
Didnt you post this same question before ?
Are you very sure about that?
The target PC/Server should be part of a domain/workgroup that has a DHCP/DNS. WinCCFlex Panel MP277 can only connect to other PC's if they(the PC/Server) are in a domain/workgroup with a DHCP/DNS.
This has given us several days worth of headaches and hairloss in the past.
The rest of the network should be fine.
ok
But if I know the name of the server on the network, and the name of the PC, then I should have no trouble ?
The MP277 specifically looks for the DNS to find the PC/Server. Without a DNS or DNS not knowing the PC/server, it's not gonna work.
The DNS needs to be specified when you configure the MP277's Ethernet settings.
Windows CE Networking
I was trying something on a machine that we have here...
Code:
StopLogging hmiDataLog, "OMTR2876_Aantal_Complete_Cycli"
StopLogging hmiDataLog, "OMTR2876_AM_PM"
StopLogging hmiDataLog, "OMTR2876_Machine_Daait"
CloseAllLogs
ArchiveLogFile hmiDataLog, "OMTR2876_Aantal_Complete_Cycli", "[URL="file://\\Zeus\data\productie\plc"]\\Zeus\data\productie\plc[/URL]", hmiCopy
ArchiveLogFile hmiDataLog, "OMTR2876_Machine_Daait", "[URL="file://\\Zeus\data\productie\plc"]\\Zeus\data\productie\plc[/URL]", hmiCopy
ArchiveLogFile hmiDataLog, "OMTR2876_AM_PM", "[URL="file://\\Zeus\data\productie\plc"]\\Zeus\data\productie\plc[/URL]", hmiCopy
ArchiveLogFile hmiAlarmLog, "OMTR2876_Stop_Oorzaken", "[URL="file://\\Zeus\data\productie\plc"]\\Zeus\data\productie\plc[/URL]", hmiCopy
OpenAllLogs
StartLogging hmiDataLog, "OMTR2876_Aantal_Complete_Cycli"
StartLogging hmiDataLog, "OMTR2876_AM_PM"
StartLogging hmiDataLog, "OMTR2876_Machine_Daait"
I'm activating this script with the schedueler every hour.
But I get this message:
Network Services cannot be started. Before you can connect you must change your computer name. You can change the name by opening the Communications control panel.
I filled in the right IP adress. Communication to the PLC works, but writing to the server doesn't happen...
Changed the computername
Changed the computername,
Now the script runs, but...
I get this system message (reason of nog copying the files):
Bij het exporteren van het archief '\Storage Card MMC\Logs\OMTR2876_Stop_Oorzaken0.csv' kon geen doelbestand '\\Zeus\data\productie\plc\OMTR2876_Stop_Oorzaken0_20090615_174101_omtr2876.csv'
worden geschreven.
The file '\Storage Card MMC\Logs\OMTR2876_Stop_Oorzaken0.csv' could not be written to the destination '\\Zeus\data\productie\plc\OMTR2876_Stop_Oorzaken0_20090615_174101_omtr2876.csv'
Any ideas ?
Pinging all okay, netwok okay now.
hmm
Writing to a shared folder of my laptop works. I think it's an IT problem (server)
worden geschreven.
Any ideas ?
Hi all, As some of our old Device net gear is failing I am planning to migrate some parts to ethernet/ip. We have 10 small cabinets with a PLC...
1,257
Hello guys, I asked some questions regarding to RSemulator before: http://www.plctalk.net/qanda/showthread.php?t=114378 thank you for you guys...
7,083
Hello all, I have an Allen Bradley DH485 network that currently has three devices. Micrologix 1500 LSP series C w/1764-24awa base node 1d...
4,618
Hi all, Can I have the HMI to be on two different networks, DH and Ethernet and have the Wonderware talk to devices on different networks at the...
7,530
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
189
