networked lighting contactors
jeff s
Aug 2007
washington
62
I have an application were I need to shut off 5 lighting circuits in one braker panel and 3 circuits in another panel that is about 5 feet away but then also need to shut off 3 circuits in a panel about 250 ft away with the same control station. is there any "smart"contactors out there? networkable were I could staple a communication cable across the roof to this remote breaker panel instead of a conduit run for control circuit.I guess im looking for a system to control lighting circuits in numerous panel from one central control? peer to peer plc? wireless? looking for suggestions
Thanks in advance
, Jeff
Thanks in advance
, Jeff
It's been a while but I remember Rockwell selling Device Net MCC components.
I'm sure other networks are available (other manufacturers as well), just never had a need for.
I would look at the EASY 800 smart relay range from Moeller and let those switch your contactors. You can network up to 8 of them together using standard ethernet cables with a maximum distance of 1km. You can control all of them from one device, or you can let each device have some control itself. Each unit can have 6 relay outputs with 12 inputs but is expandable. They are easy to program and if you want you can also use the EASY MFD in the network that has an inbuilt HMI. List price in the US is about $380 each. Moeller are now part of the Eaton group.
http://www.moeller.net/en/products_solutions/motor_applications/control/easy/index.jsp#800
http://www.moeller.net/en/products_solutions/motor_applications/control/easy_hmi_mfd-titan/index.jsp
Bryan
hi good day!! Can 2 different PC run 1 same runtime? In my main PC (Operation System) the display port already used up and i need more monitor...
626
This is an issue I see occasionally.The logic tells a drive through Ethernet to start but it does not see the start command at the drive. There is...
2,255
Have a button, an FTV native button Need to change the caption of that button based on a analog tag value For the life of me I can find no...
1,741
M
Hi , I am new to this forum. I am trying to introduce into our network a siemens PLC with an ethernet card and eventually expand the netework to...
4,436
Why AMIo800 Analog input module's I/O LED is Lighting up Red? Checked module connections, 4-20ma wires etc but this light is continuously Lighting...
112
