New and confused!
buddhaman001
Feb 2014
mobile, al
52
First off HI! I absolutely love this forum and want to thank everyone for helping me (though they don't know they have). I'm part of a startup and as such am having to learn all of this on my own, Everyone says I've been doing great but I know I have yet to learn enough to unlock the full potential of these programs.
So what I'm working on tonight is a main icon that will change color at any error in its corresponding display, to do this I'm writing an expression for a color change on the icon (I will be writing actual alarms tomorrow)
My expression list is for factorytalk. Could someone take a quick gaze and see why this is throwing a value other than 0 or 1?
Code:
If {Plant11\Booster1Fault} Then 1
Else
If {Plant11\Booster2Fault} Then 1
Else
If ({Plant11\chlorinescale} < 50) Then 1
Else
If {Plant11\generatorfault} Then 1
Else
If ({Plant11\Booster1} OR {Plant11\Booster2} == 1) AND ({Plant11\Flowmeter1} < 50) Then 1
Else
If ({Plant11\SystemPower} == 0) Then 1
Else
If ({Plant11\flowmeter2orresidual} > 1.8 OR < .7) Then 1
Else
If ({Plant11\Systempressure} < 40 OR > 80) Then 1
Else
If ({Plant11\groundstoragelevel} < 12 OR > 25) Then 1
Else 0
SORRY! that was the wrong revision.
Code:
Else
Else
Else
Else
If ({Plant11\Booster1} OR {Plant11\Booster2}) AND ({Plant11\Flowmeter1} < 50) Then 1
Else
Else
If ({Plant11\flowmeter2orresidual} > 1.8) OR ({Plant11\flowmeter2orresidual} < .7) Then 1
Else
If ({Plant11\Systempressure} < 40) OR ({Plant11\Systempressure} > 80) Then 1
Else
If ({Plant11\groundstoragelevel} < 12) OR ({Plant11\groundstoragelevel} > 25) Then 1
Else 0
Wild stab in the dark because programming languages, especially scripting languages, can be very unique.
The line that contains “< .7”, would throw an exception in most languages.
Try “< 0.7”
SWAG 
If (({Plant11\Booster1}) OR ({Plant11\Booster2})) AND ({Plant11\Flowmeter1} < 50) Then 1
Else
They look OK except this one. Maybe need syntax change (in red) or make it two seperate statements.
If ({Plant11\Booster1}) AND ({Plant11\Flowmeter1} < 50) Then 1
Else
If ({Plant11\Booster2}) AND ({Plant11\Flowmeter1} < 50) Then 1
But I think you need to Open and Close Statements on either side of argument. (statment1) OR (statement2)
It looks like all the others are like that.
I was wondering the same thing. I thought maybe he's using a Multi-State indicator and getting an Error.
I am...an idiot. It was a combination, one, the single line tag checks helps alot (removing or and ands. Also....I didn't have a RTu connected...yeah I facepalmed at myself.
Guys thank you very much for your help. I hope someday I will be versed enough in this type of software I can contribute to the forums!
Which of the following input operations require a conversion to digital form prior to input? a) disk b) analog c) contact closures d) limit...
3,896
Hey all! I recently purchased myself a Panelview Plus off of ebay and i was hoping that i could upgrade the firmware on it to Version 9 or so and...
2,760
Good morning everyone. I am apparently confused on the COP instruction. What I am trying to do is copy a DINT to a DINT in a User Defined Data...
7,008
Hey guys, Im currently using the above flex IO to turn on two outputs these outputs go to two flashing red beacon lights. Here's the scenario: My...
1,724
I'm event AV Technician (Sound, Projection, and Lighting). Over the last couple of years I've used a Weigl ProCommander PHX to control some event...
2,720
