new battery for laptop, commissioning
Kataeb
Jan 2007
www.livelovelebanon.com
636
i have replaced my laptop battery by a new one, because the old one is not charging properly and sometimes going empty suddenly.
what is the procedure for using a new laptop battery? should we charge it fully for one or two days? then let it go empty? to recharge it again?
This was an issue with NiCad batteries. Some argued they had "memory". For example, if you only ran them half way down before recharging, they would "remember" and start dying half way. You had to fully discharge to "clear the memory". Of course, manufacturers insisted this wasn't true.
Not a problem with current Lithium technology. The only reason for full discharge/recharge today is to teach the gas gauge in Windows.
Fully charge before first use is recommended for all batteries.
I will tell any one who thinks their laptop battery is faulty
more than likely it is the motherboard DC power connector.
this is subject to constant movement and breaks the socket away from the circuit board.
in some cases it actually shorts out the battery
- i have seen this in HP,Toshiba and Compaq notebooks
I like to put new batteries through several full charge and discharge (to normal levels) cycles. It has seemed to help their performance for me with all types of rechargeables.
I'm ashamed to admit this but I've never had to replace a battery in a SLC. Some how been able to skip that task in all my years. So yesterday...
260
Hi to all. On our Siemens PLC power supply, the battery light is showing amber. If we do not immediately change the batteries, will we lose the...
140
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
253
Customer is buying several spare 504 CPU's to have one handy when there's an issue with the ones in operation. Having them on the shelf for years...
2,860
Our plant has a network repeater station located in a field with two ProSoft RLX2-IHG network radios for connecting our plant network to a well...
2,432
