I've compiled this for you anyway so you know what's what...
Connected Components Workbench Release 4.0
Operating system requirements
This release is supported on the following operating systems:
Ÿ Microsoft Windows XP® SP3 (32-bit) or later (except Home editions)
Ÿ Microsoft Windows Vista® SP2 (32-bit and 64-bit) or later
Ÿ Microsoft Windows 7® (32-bit and 64-bit)
Important: Connected Components Workbench 4.0 will be the last release to support Microsoft Windows XP and Vista.
VMWare compatibility
Compatibility with VMware® has not been formally tested, but it has been used extensively with Connected Components Workbench.
Ÿ If you use Connected Components Workbench with VMware, you may have to manually switch USB connections between the guest and the host.
Ÿ If you experience poor performance using VMware with a Window 7 guest, you may need to upgrade VMware or run Connected Components Workbench on the host operating system.
Ÿ Connected Components Workbench and other software may try to access the networks, to ensure optimal system performance, you may need to disable network adapters.
Rockwell Automation® software compatibility
This release of Connected Components Workbench software has been successfully tested with the following product versions:
Ÿ RSLinx® Classic Lite 3.60
Ÿ ControlFLASH™ 12.00
RSLinx Classic v3.60, Logix Designer v21.00, and device profiles that ship with Logix Designer v21.00 are not compatible with:
Ÿ RSNetWorx v11.00 or earlier
Ÿ DeviceNet Tag Generator v11.0
Ÿ RSNetWorx and the DeviceNet Tag Generator must be upgraded prior to installing these products.
RSLinx Classic v3.60.00 (CPR 9 Service Release 6) is a component aligned to FactoryTalk View v7.00.00. RSLinx Classic v3.60.00 has been tested, and is compatible, with the following products:
Ÿ FactoryTalk Services Platform v2.60.00
Ÿ FactoryTalk Activation Manager v3.60.00
Ÿ FactoryTalk View v7.00.00
Micro800 firmware requirements
The Micro800 firmware selections for Connected Components Workbench 4.0 are:
Ÿ Micro810 controllers – major revisions 1.xxx, and 2.xxx
Ÿ Micro830 controllers – major revisions 1.xxx, 2.xxx, and 4.xxx
Ÿ Micro850 controllers - major revisions 2.xxx and 4.xxx.
Components installed with Connected Components Workbench
The following additional components are installed with Connected Components Workbench Standard and Developer Editions but they will not be removed if you uninstall Connected Components Workbench.
Ÿ Rockwell Windows Firewall Configuration Utility 1.00
Ÿ Rockwell Automation USB CIP Driver Package (x86) or Rockwell Automation USB Driver Package (x64)
Ÿ RSLinx Classic 3.60
Ÿ MSXML 4.0 SP2 Parser and SDK
Ÿ Microsoft .NET Framework 3.5 Service Pack 1 (Window XP only) that includes:
Ÿ Microsoft .NET Framework 2.0 Service Pack 2
Ÿ Microsoft .NET Framework 3.0 Service Pack 2
Ÿ Microsoft .NET Framework 3.5 SP1
Ÿ Microsoft .NET Framework 4 that includes:
Ÿ Microsoft .NET Framework 4 Client Profile
Ÿ Microsoft .NET Framework 4 Extend
Ÿ Microsoft Visual Studio 2010 Isolated Shell - ENU that includes:
Ÿ Microsoft .NET Framework 4 Multi-Targeting Pack
Ÿ Microsoft SQL Server 2008 R2 Management Objects
Ÿ Microsoft SQL Server System CLR Types
Ÿ Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729
Ÿ Microsoft Visual C++ 2010 X86 Runtime - 10.0.30319
Ÿ Microsoft Visual Studio 2010 Shell (Isolated) -ENU
Ÿ Microsoft Help Viewer 1.1 (Standard Edition only)
Ÿ Microsoft SQL Server Compact 4.0.8482.1
Ÿ OPC Core Components Redistributable (x86) 101.2 or OPC Core Components Redistributable (x64) 101.2 (if the operating system is 64-bit)
Ÿ Virtual COM Port Device Driver 6.3a
Ÿ Adobe Reader 11.0
Connected Components Workbench Developer Edition only
Ÿ Microsoft Visual Studio 2010 (Service Pack 1) that includes:
Ÿ Microsoft Visual Studio 2010 Tools for Office Runtime (x86)
Ÿ Microsoft Visual Studio 2010 Service Pack 1
Ÿ FactoryTalk Activation Manager v3.60.00 (CPR 9 SR 6)
Ÿ FactoryTalk Diagnostics v2.60.00 (CPR 9 SR 6)
Considerations when using RSLinx Classic with Windows Vista, Windows 7, or Server 2008
The following communication drivers are supported and are available on the Configure Drivers dialog box:
Ÿ 1784-U2DHP for DH+
Ÿ RS-232 DF1 devices
Ÿ Ethernet devices
Ÿ Ethernet/IP Driver
Ÿ 1784-PKTX(D)/PCMK for DH+/DH-485 devices
Ÿ DF1 Polling Master Driver
Ÿ 1784-PCIC(S) for ControlNet devices
Ÿ DF1 Slave Driver
Ÿ DH485 UIC devices
Ÿ Virtual Backplane (SoftLogix 58xx, USB)
Ÿ DeviceNet Drivers (1770-KFD, 1771-SDN, and 1747-SDN)
Ÿ SLC 500 (DH485) Emulator driver
Ÿ SmartGuard USB Driver
Ÿ Remote Devices via RSLinx Gateway
Ÿ The following communication drivers are not supported:
Ÿ 1784-PCC for ControlNet devices
Ÿ 1747-PIC/AIC+ Driver
Ÿ DeviceNet Drivers (1784-PCD/PCIDS)
Ÿ PLC-5 (DH+) Emulator
Ÿ SoftLogix5 driver
PLC Pie Guy said:
So, I am installing LINX 2.59 and CCW will be happy if I don't install it's V3.0 of LINX that is included with it?
No, I'm afraid it wont be happy.
CCW v3.0 and v4.0 need RSLinx v3.60
CCW v2.0 will work with RSLinx v2.59
RSLinx went straight from v2.59 to v3.51 before going to v3.60, there was no "
v3.0 of LINX". RSLinx v3.51 introduced the incompatibility issues you're facing, so to continue using software versions below the cut-off point, you'd have to use RSLinx v2.59 max. And as above, you'd have to use CCW v2.0 to keep everything happy.
PLC Pie Guy said:
...I am installing RSLOGIX 500 V9.00 RSLOGIX 5000 V16 thru V20.01...
That's the latest RSLogix 500 version, so that's ok.
But your real crux here is actually RSLogix 5000 v20.01.
If you installed RSlinx v3.60 to satisfy CCW v4.0, then RSLogix 5000 v20.01 would be incompatible with RSLinx v3.60. You'd have to upgrade RSLogix 5000 to v21.00. Then they could all co-exist, except RSNetWorx.
You can either upgrade it, or else live without. I'm running RSNetWorx v11.0 in VMware, so I haven't made the leap to v21 yet either.
Not too long ago I posted some info that explains why these software versions are not compatible. Ken touched on it when he mentioned the EDS files. Since RSLinx v3.51, the EDS File Subsystem has been radically changed. So certain older software versions are not compatible with the new setup and cannot access the EDS files they require anymore. Now it may not stop software, such as RSNetworX, RSLogix 5000 and CCW from connecting to network devices, but they cannot configure them automatically using their EDS files.
More info.
Seeing as you're starting from scratch on a new PC, I'd also strongly suggest you use
VMware Free Player and configure different virtual machines for each unique software configuration you might need.
G.
